Hi there,
I'm having some problems with my electric windows on my 1990 infiniti Q45 Active. The centre console which controls all the windows has no power, and does not work the windows. The driver side window control also has no power and doesn't work. Every other window however works fine from their own in-door control. The drivers side window control unit (the automatic up/down module) works when it is supplied with a direct power/ground. My guess is that there's a circuit breaker or something which has popped as all the fuses are intact and there appears to be no dodgey connections anywhere. Any ideas where the electric window control unit is? Or where I might find any circuit breakers?
Thanks in advanceMurdoch
Modified by 3rdegree at 10:40 PM 7/1/2006
