sultan »
https://forums.nicoclub.com/sultan-u295.html
Fri May 07, 2004 3:38 am
first of all, the fan is loud!
i hear the electric fan turn on every time i come to a stop. yesterday i heard the fan but ac was on so i didn't think anything of it. today it was 70 degrees ambient with ac off and cloudy and i heard it turning on. the inside temp gauge never moves above 3 o'clock and i thought the fan only turns on if overheating and for ac. i know i have a very small coolant leak near the radiator drain that i need to find, but i check the coolant often to make sure it's not low. thermostat and coolant + water wetter have been in for about a year. when i'm stopped the idle is just a tad low but within spec according to the tach. i am also using the pop-charger with a heatshield and 4" hole drilled underneath if that makes a difference.
do i have a gauge/sensor problem, some problem with the fan, or am i overheating? please help.
edit: it didn't do this before, even when 85 degrees and sunny with no ac on.
