1qckser »
https://forums.nicoclub.com/1qckser-u232.html
Thu Dec 18, 2003 8:32 pm
Here are all the specs for the runs I did, the car has 192,900 miles, the oil has 2,200 Mobil 1 5-30, knock sensors have not been changed since 1998, the car overheated once and that when they had them changed, transmission fluid has 13,000 miles on it non syn, diff has same miles but with Amsoil, tank of non ethanol fuel from MA, temp was 61.3 and barometric pressure was 29.6, relative humidity was 41.9, we couldnt get a reading on the air fuel ratio because he didnt have a cover for my tailpipes and no one wanted to stand behind the car and hold the probe, now it tooka while to get all the pereimeters setup for the run, the car ran on the dyno for about 35 minutes making slighpulls to adjust the dyno for the gear ratio and for TC slippage, we eneded up doing the pulls in 3rd because it was 1.00 ratio, my fans did come on so I know the temp was at a minimum 176, any way the #s are 227.9 hp @ apprx 5450 rpms, and tq was 239 @4400 rpm, it had 2 peaks, the 1st @5150 and the 2nd @5400, also the hp curve shows the same odd lil peaks at close too the same rpms, im gonna do it again next week because now all my info is saved and we wont have to play around with it, all in all im pleased, $1500 bucks, 192,000 thou is not too bad, I have video and will see if Sultan or some one can host it:D
