When ever you use the term HP you must specify an rpm [@ rpm] to allow engineers to convert to torque.
it was determined that the 90 Q engine produced ~~ 270-286 HP.....[the usual +- 3% variation in production].........the peak torque was UNDERRATED instead of 292 lb/ft many engine produced 300-305 lb/ft* at 4,000-4,500 rpm. * Most were on the + side 292 +3% to +4.5%Much depends on plenum air temperature since the plenum and runners are very sensitive to tuning changes as the air heats up.
They tried to broaden the reflected pulse with miniscule different port diameter and shapes in 2 input head ports.
Anyway you must specify plenum air temperature for anything to be meaningful. To be in tune 60-80F is required.
http://www.sengpielaudio.com/c...e.htm
