Q45 driver's memory setting
derrck_mullin
Car: 94 Q45/92 6 speed LT-1 Vette
OK,
sorry so many questions, but I have been doing searches to no avail. Anyway, I think I'm doing what the manual says, but the car never seems to change. I just got a 94 Q and have been trying to set the memory positions. I set everything where I want it then hit the set button. The 1 and 2 buttons both light up. I'm just supposed to push in the 1 button at this point and it's set right? When I get in the car and go to the on position, the wheel moves, but the seat never goes back to where I set it. Anyway, again the system might not work, but I might not be doing this correctly.
Thanks
Derck
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
If you follow the procedure in the owner's manual correctly, then check the steering column button is not on cancel.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
You press the set button... light comes on, press and hold until the light comes on again, and when the light comes again it is set...
96Qowner
Car: 1996 Q45
On my 96 I have to hold the 1 or 2 button down until it starts ... blinking? can't remember exactly what it does, but I know you have to hold it for a few seconds at least, not just a push.
derrck_mullin
Thanks guys...I'll try again, but I think it's on the fritz. Seems like the steering wheel goes to where I set it, but the seat slides to the rear for me to get in then just stays there...I have to slide it forward every time. Oh well, not that big of a deal. Oh and I did check the cancel button on the steering column and it is off (out...I can see the white portion of the button).
Thanks
Derck
