texasoil »
https://forums.nicoclub.com/texasoil-u1000.html
Mon Feb 16, 2004 5:41 am
It depends on your tolerance for vibration.
The only practical way to return your car to absolutely smooth driveline is to restore it to OEM state--new engine&transmission mount, new exhaust hangers, new driveshaft, maybe new differential bushings too.
That said, a conventional yoke is not recomended as it will send speed variations up and down (down the driveshaft, up to the transmission) twice per revolution unless it has a zero angle of deflection. I don't think the 'rubber' coupling between the inner and outer rear sections of the driveshaft will last long with that constant torsional vibration--maybe it will.
The 'rubber' drive disk is carefully designed to absorb the torsional vibrations caused by its angle of deflection so as to keep the driveshaft and transmission under constant load--no speed variation of the driveshaft.
I really don't think any modification that is even close to OEM smoothness can be done for anywhere close to the new shaft from Scottsdale Infiniti.
IF you are tolerant of driveshaft vibration, or drive only at low speeds, maybe the hard yoke will work OK for you.
