rsiwicki wrote:I thought I read somewhere that you could put a 6.5" in the door easily enough and there was actually an aftermarket bracket from the 300ZX that fit our Q's in doing the larger speaker upgrade.
If not a 6.5", what about a 5.25" speaker in the door? Any clearance issues with this size?
I think the only thing that may limit the use of a 6.5 is if you want to modify the existing plastic bose speaker pod. Then the limit is the mounting depth. If you remove the plastic pod, I think you're pretty wide open.
IMHO, 5.25's are plenty for front stage, but the 6.5's should fit.
