mrq45ss wrote:q45tech now when u say exploding. u mean like really exploding? and when u say jamming meaning that the tc is not turing and clutches are locked up.
Meaning you would hear it if the torque converter went out on you.
mrq45ss wrote:when i just start up the car from cold start it selects gears and move but when it reaches operation temp it stop selecting gears and stop moving.
Try looking at the transmission fluid temprature sensor. Much easer done with a consuld or Volt/OHM/ Meter.
Do you have the service history on this car to see when the tranmssion was last changed and flushed?
The pump will whine when cold on some cars. Not sure how to explain it.
But other than that make sure the TCU is OK and tha harness going to it is fine.
Modified by Paul Wall at 7:33 PM 10/27/2009
