RobertsnewQ wrote:
Rear diff is not interchangeable (different axle flanges).
TWIN TURBO rear diff is interchangeable... The NA had the 5 bolt, the TT had the 6 bolt.
Honestly i saw this thread and didnt catch it soon enough, so i got too lazy to read it. Ok... Heres my .02
First off, addingthe manual to the Q isnt going to be a big deal... Its even easier with the Z32 setup due to its shifter design... ITs got that kinda weird rear mount shifter instead of a stick literally coming out of the transmission... All you have to do is fabricate a new thing and you can precisely put the shifter where you want it... I measured it and I think the shifter will be right on... The tip of the shifter is like 30in away from bellhousing of the transmission..... It will come REAL close to matching up perfect, and if its too short its fine... If its too long then we run into issues.
Clutch MC will go right where the Cruise control servo is, just move it to the otherside or take itout if you dont want it.... Just drill some holes nad mount a support plate... once you move the BCM out of the way theres plenty of room...
I feel like Im calling you out Greg..... And, I guess I am.....
E brake isnt gonna be a big deal.. Just use a Z32 e- brake and make a bracket for it by the seat... The E brake cables go right next to the drivers seat... Cool how that works out, eh? i reckon if oyu wanted to you could just rock and chop it the cable and hook it up to a lever...
The MT should bolt up to the factory mounting points, and with that being said, the twin turbo driveshaft has the same spline pattern as the Q.....
SO basically, the MT bolts up with adapter plate, no fabrication to mount it to the car, driveshaft is a non issue, all you have to do (i use that term lightly) is make sure the shifter goes in right (it should).. weld in a plate for the shifter support bracket, and then put in a clutch pedal.. The most custom fabrication I see coming out of this, at worst, is new lines for the clutch MC and slave C.... Everyone knows the flywheel bolts up, and thus we use 300ZX clutches...
Why hsant anyone done this again!!!!!!!?
G50 Q- Knock it off....... ill delete posts, but we'll leave em for now, but hopefully you got everything you wanted to say out... Dont appreicate that sort of negative comments, or at least the way you chose to say it.
About the coilovers: Ive ruled out using Z32 coilovers since the mounts are so much different... Yes, you can make them work, is it worht it? I doubt it. R32s should be a direct swap from what I can tell from looking at service manuals... Ive posted the diagrams somewhere, i know what they look like, if your interested search and ye shall find..... worst case I see with that is having to tweak the adjustments..... The shocks may be slightly longer on the Q...
