Q45 diff.
Piston1047
Car: Black 1994 Q45t
Ok guys, I think my diff. or a part of it is dying or dead. roaring during acceleration and at it makes a whoov whoov whoov sound like a bad tire when slowly gliding in drive. After researching a little i realize that a new diff. is probably 2/3rds the value of my car. I just wanted to get an opinion on other/better/CHEAPER options. i have read around nico and q45.org and i see that the Y33 can use a Z32 one and I know the G50 is a R200v. Thanks folks.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
G50 has the six bolt flange. TCS has different differential accessories also.
What is the car worthto you?
Q45tech
We change many diffs on high mileage Q/J......find a low mileage junkyard one................~~$300 the newer year the better. Only 90-96 will fit.
Replaced mine at 225k.
goody90q45
Car: 1992 Infiniti Q45 (sold)
There's one on ebay right now for $24 (with no bids yet) and $110 shipping, from a 94Q with 130000 miles.
Q45CALIBER
Car: Black on Black 94 Q45
maxnix wrote:What is the car worthto you?
My thoughts exactly.
guadofreak
Car: 1994 Q45t
the diff in mine was replaced around 100K with a junkyard unit. I now have 170K on it. Seems to be holding up. I guses some are just prone to dying.
JohnPa
Car: 1990 Q45t
Q45tech wrote:We change many diffs on high mileage Q/J......find a low mileage junkyard one................~~$300 the newer year the better. Only 90-96 will fit.
Since the topic is replacement rear ends, here's an idea I've been playing with. I would like the 4:08 rear end in my 90 Q45t, but haven't figured out how to make the speedometer work even after searching all of the posts. What about using the differential out of the 97-01 Q which splits the difference between the 3:54 and 4:08 ratios, but should bolt right up. Then, and here's the real question, fit the speedometer sending unit from the newer transmission to the older model transmission.
What do you think? Will this work?
Just an idea.............John
sijoko
Car: Black 1994 Infiniti Q45 Turbo, Pearl White 2014 Maxima Sport
The 90-96 differential has the 6 bolt flanges. If I am correct, the 97-01 Q diff has 5 bolt flanges.
As far as the speedo calibration for the 4.08, I am using the plastic gear for a 3.9 ratio. Once you get past this size, the plastic gear will no longer fit on the VSS of our cars.
So I just went with the 3.9 VSS gear. The speedo reads a bit optimistic, less than 5%.
If you run taller tires in the rear, then this would work out perfect.
RobertsnewQ
1. later diff (Y33) does not bolt up. It's the same as 300zx2. Speed sender isn't the problem - it's the speedometer that tells everything else how fast the car is going. The Nissan system uses the speedometer in the dash as the "head" - it calculates the speed based on the speed sensor & known axle ratio. Maybe you could use a R32 or Z32 speedo mechanism? I've never looked at it, but it might be possible to modify the speedometer to send the proper signal.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
you should be able to use that little yellow box.. but the VSS swap is the easiest IMO... the difference between 3.9x (in the J30) and 4.08 isnt much to cause that big of an issue...
itd be useless to go to a 3.69 diff... thats a waste of money and time IMO!
DrewQ45
Car: 1990 Infiniti Q45
Did you replace yours out of necessity, or proactive maintenance? Wonder how long mine will last. Pretty quiet so far (198K)
Had my diff fluid changed years ago at T-3 when I did my guides (you might remember Tech) and changed it again a few months ago to synthetic. Hopefully that might drop the operating temp a few degrees. I keep coming across people who tell me I don't need to change diff fluid...ever! I tell em.... "sure...cause Nissan made the drain and fill plugs just for show!"
Boy that stuff stinks!!! That magnet does a pretty darned good job of catching particles.
redmanfx
Car: 92 Q45a
JohnPa wrote:
Since the topic is replacement rear ends, here's an idea I've been playing with. I would like the 4:08 rear end in my 90 Q45t, What do you think? Will this work?
red
JohnPa
Car: 1990 Q45t
elwesso wrote:you should be able to use that little yellow box.. but the VSS swap is the easiest IMO... the difference between 3.9x (in the J30) and 4.08 isnt much to cause that big of an issue...
OK, help this novice out here. What is the 'little yellow box' and the "VSS" you are referring to? Sounds like this can be done if I get the right parts!
Thanks.............John
elwesso
2007 BMW M Coupe
yellow box is a vehicle speed interpriter.. rob tried it but it didnt work..
VSS=vehicle speed sensor
JohnPa
Car: 1990 Q45t
Wes, one last question on this issue. Does the J30 have a 3.9:1 ratio differential? If so, why not use that in an early Q and the speedo gear mentioned above to get the speedo to register correctly?
Thanks..............John
dousan_pg
Car: 1995 240sx 1991 infiniti q45 1993 nissan 240sx
yes j30 is 3.916
CVS
Car: Infiniti Q45, Merc S320, Lexus Soarer TT
Hey "Q45CALIBER",
Where did you get those BMW style "Angel Eyes" on your headlights?They look the biz! Ya da boz man! How much did it set you back? I presume you installed them yourself?Hope they are available for order online as i am in Australia.
RegardsCVS
Edit: piston1047, Oops sorry for accidentally hijacking this thread... Did not see q45calibre's "Angel Eyes" thread(s) until he pointed them out. Been 12 months since i came back to this forum forgot how it worked. Thats why i shall forever remain a "newbie"...
CVS
Modified by CVS at 8:04 PM 4/10/2006
Modified by CVS at 8:11 PM 4/10/2006
elwesso
2007 BMW M Coupe
JohnPa wrote:Wes, one last question on this issue. Does the J30 have a 3.9:1 ratio differential? If so, why not use that in an early Q and the speedo gear mentioned above to get the speedo to register correctly?
It doesnt bolt up.. it uses the 6 bolt flanges with 3 groups of 2 instead of 6 evenly spaced
Q45CALIBER
CVS wrote:Hey "Q45CALIBER",
RegardsCVS
Thanks CVS. Here you go.
zerothread?id=164207
zerothread?id=165785
Wes-I think I read on e of the post you we saying that you dont have that many dead spots accelerating with most of the mods you have done. Is there any reason you have not put the 4.08 diff on your car?
Trying to decside if this is what I am going to do. I guess I will not be trying to take the car to its top speed that often.
elwesso
2007 BMW M Coupe
Q45CALIBER wrote:Wes-I think I read on e of the post you we saying that you dont have that many dead spots accelerating with most of the mods you have done. Is there any reason you have not put the 4.08 diff on your car?
I guess you could say i just havent gotten around to it. I was going to buy a diff last fall, but i never did it because by the time i was ready to buy it was almost winter. Dont need the 4.08 in the winter!
Thats basically the only reason i havent done it yet!
