1. Yes2. Yes3. no, except there are 2 extra sensors for TCSvqpwrd240 wrote:1. do all 90 thru 96 q45's have a limited slip differential? 2. and do they all have a 3.54 final drive? 3. does it make any difference if it has traction control or abs? thanks for the info.
Thus, only the TCS equipped G50 have four wheel ABS. The other G50 just use the locked rear wheel as the value for the still turning wheel. Hence, in reality, only two front and earliest locked rear wheel 3 wheel ABS.rsiwicki wrote:On the TCS differential there are 2 sensors (one for each half shaft) that function both as your ABS and TCS sensor.
On the non-TCS differential there is only 1 sensor for ABS that attaches next to the driveshaft yolk.
