q45 diff on s14 rear end questions
Amandrews702
Car: 1995 S14
OK so i was told that the LSD from a q45 would work on my s14, and i want to know if thats true, and if it is do i have to change the entire rear end (axles, pumpkin, hubs, pinion, etc...) or will the diff fit withe the stock s14 parts? probably a stupid question but i don't know too much about Nissan rear ends. i don't really check my messages on here, so if whoever knows could text me id appreciate it!!
Andrew
7025015117
SKILLVIA
you have to swap hubs, axels, pumpkin. you can either modify driveshaft or use q45 and modify it.
you have to use 1 q45 axel and 1 tt 300z axel. there is a good write up on doing the swap. try searching for it.
