After reading the q45 lsd swap article posted all over every 240sx forum I decided to do the swap myself for my s13 but have few questions. I allready know I need z32tt AND q45 driverside axles and q hubs But not sure which ebrake setup 2 use. I found this on FA:
"If you already have a 5 lug swap and you use Q45 hubs, the anchor pin for the parking brake is different. ( At least its different from the R32 style ) but can be used with the backing plate you have. Just make sure you get the anchors from the Q45 brake setup. (If you don't understand what I am talking about, the anchor pin I am referring to is the pin held in place by the 27MM nut for the parking brake shoes to sit against.)"showthread.php?t=172393
Can anyone confirm this before I go to the JY and start snatching parts
Modified by SxMachine at 5:20 PM 6/18/2009
