Q45 Denver exhaust manifold install Q?
squeefoo
Car: 1990 Infiniti Q45
1994 Nissan Maxima SE
1999 Infiniti I30
2003 Nissan Maxima Titanium
2006 Nissan Xterra Off Road
2012 Infiniti G37x S
Hi How much of a pain was it to put in the JDM ex. mans. ?I've had a set ready to go for the last year or so...
Just a brief description will suffice. ...like jack the engine up, remove starter, etc.
Did you re-use the gaskets if there were any?
Thanks a lot !
Q45denver
Car: 1995 Infiniti Q45t
1990 Infiniti Q45
1998 Nissan Frontier
Since I intalled them with the engine out of the car it was no trouble at all. I did use new gaskets. Some just punch out the precats,
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Thats what I did (punch the precats)
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Before you do, might want to check on Q45tech ancient post.
No gains.
elwesso
2007 BMW M Coupe
maxnix wrote:Before you do, might want to check on Q45tech ancient post.
No gains.
Yeah hes right... it really didnt do anything, but did make the exhaust a little raspier.. Kinda sounds cool
Q45tech
The precat honeycomb is designed to expand with heat and offer less and less resistance as the engine warms up............just there to function in the first few minutes of a cold start.
Why gutting/removing doesn't do much for mpg or power.
PopPop
Car: 1990-91 infiniti Q45's, S13 Coupe, 3rd GEN. Max
Q45tech wrote:The precat honeycomb is designed to expand with heat and offer less and less resistance as the engine warms up............just there to function in the first few minutes of a cold start.
Another advantage would be to gutting pre-cats would be you would never have too worry about them getting clogged like the 2 cat-converters do sometimes? Right or wrong? Would this shorten or extend the life of your EGR AND O2 Sensors or have no effect?
Q45tech
Never seen a precat clog................ocassionally melt into a solid mass from bad injectors/MAF etc..............but that usually causes other problems on piston crowns/exhaust valves, stem seals so punching them out doesn't solve much..........requires engine tear down/replacement.
If anything the EGR would not function as well as designed because there would be less back pressure at cruise rpm..............we are speaking of tiny back pressure but some is necessary to send EGR up the tube.
