elwesso wrote:When me and Evan had the altima 2.5 with CVT, it was interesting. For regular driving it wasnt too bad for just sloshing around town.. Basically, if you left it in drive and were just poopin around town you wont mind.
This one had the 6 speed "sport shift". That really made the car fun because it simulates 6 gears. it "shifts" faster than Evan's GTI did and was quite a bit smoother...
Im not aware of any CVT setups that are used on longitudinal mount RWD cars.
Basically the way CVTs work is they have 2 different sized pulleys connected together with a belt... As one gets larger the other one gets smaller. The pulleys look similar to 2 cones put tip to tip so the pointy ends are touching. hydraulic pressure (or spring pressure in things like ATVs and snowmobiles) causes the pulleys to either get wider or narrower, thus decreasing the diameter that the belt contacts.
i could have sworn that the murano i drove was RWD, and had a CVT, i hated it
never lliked the idea of a transmission being (basically) a big rubber band that tightens the faster you wanna go haha
