qship96 wrote:does your year Q allow 10w-40 oil per owners manual?
FSM for the 90 Q45 says 5 7/8 quarts (with filter) of API service SG.An accompanying chart allows for SAE viscosities of 5W30, 10W30, & 10W40.
More specifically, on MA-10, they write (verbatim): "10W30 is preferable if the ambient temperature is above -18 degrees C (0 degrees F). 20W-40 and 20W-50 are usable if the ambient temperature is above 10 degrees C (50 degrees F) for all seasons."
It seems to me that a 15 year old Q might be "worn" a bit so that's why I figured on the 40 second number (the first number, 10W or 20W, only lasts about 5 minutes in my opinion as once the engine heats up, the oil doesn't know that it's winter outside anymore so the only number that really matters after the engine heats up is the second number in my opinion). I could be wrong, but, that's why I go with 40 weight oil. In New York things were different (those first five minutes were killers); but in California, in the low lands anyway, it never gets cold like NY so 5W isn't really called for in my opinion.
In reality, I'd bet we could get away with a single-weight oil (less carbonization from additives) in CA valleys (as long as we don't go skiing).
