ddrumman »
https://forums.nicoclub.com/ddrumman-u17019.html
Mon Jun 07, 2004 11:14 am
Hi Guys, New here to the Nico brotherhood. I’m happy there is such a source of good information for our beloved Q45s.Here’s some info on the car. It’s a 94 standard model. I bought it in Oct 99 ( its’ 6th birthday ) with about 68,000 miles on it. It now has 113,000 miles.
It came with an extended warranty that would expire right at 100,000 miles (nice). And btw I renewed right before 100,000, so now we’re good until 135,000 miles or Oct. 2005 whichever comes first. So, as far as big repair bills go, I’d say/hope I’m covered.
Mods are: Eibach Pro Kit, springs, Tokiko blues, front and rear, Stillen FSTB. All installed by Stillen.
I’ll try not to waste time and talk about things that have already been discussed. Use the search engines etc.I have a lot of questions/thoughts but I’ll stick to a couple for now.
My questions/thoughts:1. Is it safe to switch to Mobil1 at this point (113,000 miles), for my fluids oil/trans? The dealer put 6 quarts of transmission fluid at 105,000 miles. When would you suggest the next change? 2. If I should get a transmission cooler, would that void my warranty?
3. I’m thinking of getting 17x8 wheels with 245/45 or 235/45 tires.Also I entertained the idea of 255/45 but maybe that’s pushing it. I’ve been under the impression as far as tires go, that the bigger the 1st # is providing the 2nd # is the same, the better/higher the load rate. (45% of 245 should be more than 45% of 235)I’m puzzled with the ratings/specs on some of the tires at Tirerack. For example the,Continental ContiExtremeContact in 245/45 is 95 w SL 400 AA A 1521lbs. 44 psi. While the same tire in 235/45 is 93W SL, 400 AA A, 1433lbs, 44psi, (makes sense.)
However with the Yokohama AVS ES100 it’s totally reversed.The 235/45 is 97W RF, 280 AA A, 1609lbs, 50psi, while The 245/45 is 95W SL, 280 AA.A, 1521lbs, 51psi
I’m looking at these tires because, as far as cost/specs go, they make the most sense.Also I’d prefer the 245/45 because it’s 25.7 or so, which is closer to the 26.1 factory.
Now as far as the wheels go, how important is it to have a “light weight” rim like say 16 to 22 lbs. vs. one that weighs 27.5 or so lbs.?
4. My last question/thought is on the rear sway bar.I’d love to find one that’s 22mm however I think that’s wishful thinking. I’ve read Dennis’ posts on this. So I’ll stick to reality and most likely get the A kit.Do you guys think I need to go to someone like Tucker’s in San Diego for the install or would the Dealer do ok? Is it a bolt on type of install or are there any mods that need to be done so it can go onto the standard model?Thanks in advance.
D.
