maxnix wrote:Under direct vacuum, oil should be drawn out of compressor.
Oil is not vacuumed from a compressor, else you wouldn't be able to add oil to a compressor prior to vacuum. There's a reason for a drain plug.
I replaced mine with a used compressor. I laid it on the side and let it drain for an entire day. The drain plug is pretty obvious, looks basically like the transmission/oil drain plug with low head clearance on the nut.
To be honest, I don't think you can drain it properly without removing it. I'll have to look but I don't remember the drain plug sitting at the bottom when installed.
