Q45 Complete Brake Swap???
93RPS13
Car: Cars, Girls, Cars, Food
are there any writes or anything on swapping the rear Q45 brakes with e-brake???? Thanks
lessthanjakejohn
was the 300zx one not good enough for you :P
trpower7
It's the exact same as the Z32 brake. You need to go get the cable from a Q45 so you can convert it to that mini-drum style e-brake. There is a writeup on http://www.freshalloy.com
lessthanjakejohn
trpower7 wrote:It's the exact same as the Z32 brake. You need to go get the cable from a Q45 so you can convert it to that mini-drum style e-brake. There is a writeup on http://www.freshalloy.com
tr have you seen this: http://importnut.net/300zxbrakeswap.htm#frontbrake
93RPS13
i did not do the 300zx brake swap , because i wasnt shore that the the brakes would fit under the wheels..
lessthanjakejohn
it is the same concept though...
