duckman240sx »
https://forums.nicoclub.com/duckman240sx-u11254.html
Wed Jun 10, 2009 6:27 pm
I need to know where the color wires go for a gen 1 CAS
I was reading the FSM to test the CAS and it says to check pin 1 and pin 2. Well my connector right now has pin 1 as ground (blk) pin 2 as hot (blk/wht). How the hell can i check for 5v-0V when the damn hot has 12ish volts already when the ignition is on. Right now i am trying to found out why my q45 wont start and figured maybe this section could also be of a little help.
Right now with the connector off the voltmeter reads 1 = 0, 2 = 11 volts, 3 = 5.16, 4 = 5.16. Connected 1 = .02, 2 = 11 volts, 3 = .20, 4 = .20. This was just still i didnt spin it because i was just saying stuff.
Right now it looks like this
CAS <-- pin 1 Black --> DRIVER SIDE pin 2 Black/White pin 3 Green/Yelllow pin 4 Green/Black
So if someone has a close up of the 4 pin harness with what wires are going where, that would be awesome. Since pictures sure do help out
