hmong503 wrote:thanks guys, were is a good place too order some cross drilled rotors and what brand? i know you said you can use both altima and q45 rotors but what would be the best to go with?
You want cross drilled just for looks?Cause they don't actual help stopping.If you want them for looks I have no idea..
If you get q45 rotors you'll have to drill them.If you get altima rotors watch that your pads don't get down that low because if you have q45 calipers the piston can over-extend if you use altma rotors and let the pads/rotors wear alot.
