Jesda »
https://forums.nicoclub.com/jesda-u7038.html
Mon Oct 04, 2004 6:47 pm
I already did that. Also cleaned MAF, MAF connector, TPS connector, CAS connector, new plugs, 94 TCU, ran BG44k... the plugs and TCU made the largest difference. My old fuel pump control unit should be ready to go in a week. I had a friend solder two wires Tangalora-style based on his photo and description.
I'm also considering a fuel injector cleaning. Tell me if this theory has any validity:As I'm cruising, excess fuel is being dumped in by dirty injectors, causing it to buck because its running too rich.Though I once had it happen while passing (on Sunday coming home from Indy). It started bucking, so I gunned it, and it had a hell of a time accelerating as it was bucking. Typically, a romp on the gas made it go away for a while.
So I'm pondering a pressurized injector cleaning.
*sigh*
Nissan fuel systems are such worthless trash. If there's anything where GM > Nissan, its making injectors and pumps that can handle the sulfur-loaded crap we pump into our tanks.
-Jesda
