nismokid wrote:i need a brake upgrade soon. will the q45 brakes fit under my 15in wheels? If so is there anyone that sells these as a package? or do i have to go to a junkyard and find them? Is my not having ABS going to affect this? Do i need the master cylinder from the Q?
thanks in advance
p.s. i tried to search but i couldnt find anything????
i know, tooooooo many questions at once, but i need to do this soon.
Q brakes *should* clear 15s, as the Q originally came with 15 inchers. Nissan Motorsports sells the package, but you're better off going the salvage route, much cheaper. Doesn't matter either way about ABS, the hub is the only different part and can be interchanged anyway. Master cylinder is not required, unless you just want it, but the Q cylinder won't work. If your car is a 5speed, you can swap up to an automatic MC very easily giving you a 1/16" more bore, not much but noticeable.
