Genpac »
https://forums.nicoclub.com/genpac-u162207.html
Wed Dec 01, 2010 4:48 pm
Has more to do with brake balance. With larger calipers in front and no abs you might get the fronts to lockup first due to increased friction area. If you mainly brake while in a straight line, you will see better braking performance, although increased nosedive. It will get a little less manageable while braking in a turn.
If you weren't going to do the rear brakes, installing an adjustable prop valve (rear circuit) can balance it back a bit, caveat being increased load for the smaller rear brakes.
Then there's the issue of pedal pressure vs. line pressure vs. piston volumes, but we aren't talking about a real serious brake upgrade. (smallish 1 piston to smallish 2 piston)
Recommended for a street car, forsure.
