DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Mon Oct 07, 2002 3:32 pm
I'm guessing you can use the same Q lines, assuming the fittings are all the same size. But if I was going to spend the money on the brakes, I'm sure I could squeeze out a bit more for new lines. As far as performance, the new calipers should require less pressure to get the same stopping force. P=F/A, so if you're increasing the area of the brake pistons, while keeping the force on the pads the same, then the pressure will be less.
