DevonD »
https://forums.nicoclub.com/devond-u85542.html
Wed Nov 12, 2008 11:52 am
Oh. Well the only Issue I could see with that is that the caliper probably mounts further out if the disc is larger too. Then you will need an adapter plate or something. I saw someone put the Brembo brakes off of a 350 on a Maxima but had to use an adapter plate. But there is no reason it wouldnt work. It just might take some custom fabrication.
