RatedR »
https://forums.nicoclub.com/ratedr-u4104.html
Wed Mar 01, 2006 7:26 pm
I've had this setup for a good 1yr+, both on my car and my wife's. I've got the brembo crossed/slotted type paired w/ AXxis semi's. So far the only problem I have is that the hose doesn't hold its own temperature wise. I've had the car w/ these brakes for more than a year, and w/ constant abuse, the brakes are still 90-95%~!!!!!!!! Just remember to use a TORQUE WRENCH on all your lug nuts (80-ft/lb). Also, you'll need to bleed the lines, the brake fluid boils rather easily. Either bleed them, or upgrade to the german fluid for $16 a bottle.
Either way, the brakes are good, even if you dont buy the axxis or performance, just the size difference alone is enough for a great improvement. E-mail me if you have any other questions, I've got pics on my cardomain page......
