q45 brake conversion, peddle is mush!
Fricshon
Car: Soon to be owner of 240sx hatch with sr and t28
someone chime in, I just did the conversion, full rebuild done by myself, bled the system with the car OFF, still get sloppy peddle. I'm thinkin there is still air in the lines and it just needs to settle out. Let me know what you guys think. I had a leak on one of the calipers, took them both off, pulled the pistons, checked the seals, bolted back up, no more leeks, bled again, sloppy peddle. HELP, I want to stop and FAST
srpowered240sx
Car: 90 240sx-sr, 92 F-150, 00 bmw 323ci, 1991 s13 coupe, 99 F250 Dsl
bleed it again. ive bled brakes for 20-30 minutes before it was getting a clean bleed. if you need help, i live in arcata as well, ill try to help you out.
btw, is this steve?
Fricshon
hellz yea it is, I just worked it out. It was the brake assist rod that needed to be extended, now my wheels lock up at 65mph OMFG! Q45 brakes rule. I'm gonna write up a lengthy definitive q45 brake upgrade post to get ride of all these holes in people tech articles.
srpowered240sx
Fricshon wrote:hellz yea it is, I just worked it out. It was the brake assist rod that needed to be extended, now my wheels lock up at 65mph OMFG! Q45 brakes rule. I'm gonna write up a lengthy definitive q45 brake upgrade post to get ride of all these holes in people tech articles.
good call man, and ill start looking for a set of my own.
modulation
How did you adjust the assist rod?My brakes are nice and firm, but there is like 1/8" of dead pedal before it actually does anything.
Daily Driven 240
Car: s-13
i also would like to know what exactly you did to the assist rod to get a firmer pedal. i have the Q45 caliper upgrade on my car and like you my pedal is mush i just figured since the calipers were bigger they required more fluid to move the pistons hence pushing the pedal in further then normal.
jianwei
Car: silvia s13
i from jamaica.. lol u can actually count the s13 in jamaica need a little help too im a newby on the s13s.. i did this conversion to my too but have a little problem.. wen im speedin not very fass est.70kmph and brake up one side of my wheel locks up and other brake smooth.. wat is causin this? already bleed my brakes...
carkook
I would be careful adjusting the push rod, if you adjust it past the compinsating vavle in the master cyl. it wil result in consntant pressure and make brake drag. If the petal was spongy with out adjusting it could have been a leak in the primary cup seal in the mast. cyl. This would cause a loss in pressure in the brakes without leaking any fluid. Sounds like you got it to work out though.
Terrorinc17
Car: S14
jianwei wrote:i from jamaica.. lol u can actually count the s13 in jamaica need a little help too im a newby on the s13s.. i did this conversion to my too but have a little problem.. wen im speedin not very fass est.70kmph and brake up one side of my wheel locks up and other brake smooth.. wat is causin this? already bleed my brakes...
You may have a caliper sticking. Take off the side that doesn't lock up. Make sure the bracket slides and pistons can be pushed back.
Check the rear calipers too. If one is hanging up it can cause the same effect on the front.
If all this fails swap the pads from left to right in the front and see what happens. Sometimes the pads get glazed and cause a pulling problem. If this is true just change the pads.
EightyNine240SeXi
Car: 89 Nissan 240sx
what did you do to adjust the brake assist rod. i just did a Q caliper swap with altima rotors and the pedal goes to the floor even after a lot of bleeding. the master cylinder was good before the swap
