The maximum pressure in the cooler lines from the TC is 30 psi.Members mistakenly believe the cooler then directly feeds the transmission pan. It does not!
The output of cooler feeds the rear planetary gears and the transmission middle then drips into the pan where the pump sucks it up....splits the flow 3 ways to other sections and the TC input.
The cooler only sees 4 quarts per minute of flow.........while the pump may flow 2-3 times that amount.
So it takes 2-3-4 passes thru the cooler to cool or filter all the 10 quarts of ATF....[4 quarts per min].......once every 2.5 minutes.............this is 3 times faster than Toyota uses on LS400.
{interestingly the SAE testing standard requires 4.5 quarts per minute of flow 0.086 +- 0.003 L/sec}
http://www.swri.edu/4org/d08/A...f.pdf
The airflow past the transmission and transmission pan, the multibolt connection to the bell housing and to engine block is all a serious part of overall cooling...........the engine block should be no more than 200-220F........so that is relatively cool.
Most SAE test ATF to 272F for a max of 70 hours or until failure.
Another test uses 93.3C [181F] for 10,000 cycles
http://neptune.spacebears.com/....htmlh ... age25.html
