Postby
qship96 »
https://forums.nicoclub.com/qship96-u3104.htmlThu Sep 08, 2005 8:37 am
according to me service manual,caster is way out of spec? even with newer tension rod bushings,why? and what would correcting it due for the feel,handling,and tire life,anything?
I usually set the front toe with a little more toe in. Say instead of .08 degrees total i might set the around .12 degrees total. They tend to have inside tire wear.
Positive toe-in readings on a Hunter or similar alignment rack mean toe IN. Negative readings mean toe OUT. His is fine, although Infiniti TEch says that .8 degree total might be low for this particular car. It is most definitely IN.
