q45 alarm keeps going off/sounding
whutsupdoc
hello all.... i have a 94 Q45a and lately the darn alarm keeps sounding!!!! there's no intruder or wind to shake the darn thing. anyone have any ideas as to why it sounds/alarms??!!!
Jberger
I'd check the door sensors in each door. The rubber cover of one of them is probably torn and it can cause the alarm to go off as the door moves.
If the dome light comes on while your driving that's a sure sign!
Otherwise you might have some major electrical issues, was this car flood damaged or rebuilt?
whutsupdoc
well... after the darn alarm went off for the 5th time... i went outside (in the dang rain no less).. opened and closed all the doors... then waited for the alarm to sing again... . guess what.. it didn't....!!!! must have been the door was ajar (though they were all closed)!!
Jberger
Doc,
Glad to know you got it fixed, those kinds of problems will drive you NUTZ. (I know!)
BTWI hate to say this but, you really need to use the search engine first before posting. There is a ton of great info on the site, so take a few hours, read them (esp. anything by Q45tech). It will save you big $$$ and frustrations.
whutsupdoc
dammm dammm dammm...
the darn alarm started honking again... the last time at the grocery store... with the PA annoncement saying "attention please... if you are the owner of a black infiniti...your car alarm is sounding!!!!)... i guess it could have been worse... like "price check for kotex super maxi pads"... but i got home pissed..took in the groceries and guess what...... ahhh dad your alarm is honking again.... i ran out thru open the hood ... yanked off the fuse box... and pulled off the @#$% anti-thief fuse!!!!
ok.... i've vented.... any help is truely appreciated if i can get this alarm thing fixed on the cheap....
i swear...... i'm staying with BMW from now on
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
So what have you done to diagnose the problem? Door sensors that JBerger suggested seem like a good place to start.
whutsupdoc wrote:dammm dammm dammm...i swear...... i'm staying with BMW from now on
The BMW service writers and mechanics are always looking for fresh wallets to empty!
Q451990
You might also check your hood pin switch. If the lights aren't staying on - I'd say you can rule out the door pin switches. They're either grounded or not - and since they control both. The trunk also has a switch.
Heath
juiceman
I do not know about the Q but my J30 will not even lock the doors and I assume set the alarm if a door is open or hood open.
If this is the case then it has to be a switch that is intermittent.
Do you have a continuity tester? Check the hood switch and door sitches while operating the units to try to simulate an open. I think that a switch is faulty thus allowing the alarm to arm then opening after a short while
Highway Q45
Car: Auto-X, Porsche 944's, woodworking, GreaseSlinger
Does your security light blink (lower right instrument cluster) when the car is closed up tight and the key is out of the ignition? If it lights up you have to find that bad switch, probably the hood due to the high heat in there, that's where my problem was. Had to replace only the rubber boot. Like Juiceman said, if there's a bad switch it can't do anything but keep setting off the alarm. Good Luck
whutsupdoc
thanks for the input guyz... i've checked everything... the security light does light up on the dash when i lock the doors (blinks just it always has) . i'll check the hood button when it stops raining in these parts.....geezzz i must have a cloud over my head, b/c by the time i get home from work it starts to freckn' rain.
Highway Q45
I guess I should have said "does it light up and keep blinking after 60 seconds?" It's supposed to blink on and then go off when it sets alarm mode. If the light goes out, I would think your switches are OK and the problem is elsewhere. I would gut the whole thing and get an aftermarket alarm/remote entry system if you don't find the problem. I hate having to use the key to open my 91.
roughyear
well after about 10-12months of no more flase alarms, my '94 Q is sounding its alarm/horn again!!!.. only the horn comes on.. no flashing lights!!
i didn't do anything special last time other than to slam shut the doors, trunk and hood a few times!!
where is this 'hood switch' that some of you guyz are talking about??
also, if i pull out the the FUSE for the security system.. why does it still trigger and the alarm/horn sounds??
