Q45 AFM Turbo or Non Turbo
B120WNY
Hi, Im looking for info on how to tell the difference between the Air Flow Meters on the turbo and non turbo models. part numbers of the two would be great.
Im looking at buying one to use on my GtiR but the guy doesnt know if its the right one, as it needs to be from a turbo model.
Thanks in advance guys ! !
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Hi, welcome to NICO!
B120WNY wrote:Im looking at buying one to use on my GtiR but the guy doesnt know if its the right one, as it needs to be from a turbo model.
Actually, there is no turbo Q45.
BUT, if you're referring Q45 vs Q45t: The "t" doesn't mean Turbo, but rather "Touring."
As far as I am aware, the AFM is the same for both. Our resident Q experts should be able to give a definitive answer. I'm going to move this to the Q45 forum.
CrimsonQ
Car: Purple People Eater
Both are the same
Only difference is connectors between 90-93 and 94-96
You sure this guy knows what hes doing?
Or is your post titled incorrectly? Maybe your looking for the Z32 maf?
Modified by CrimsonQ at 6:50 AM 12/19/2006
B120WNY
Thanks for the info guys. I was under the impression there was a turbo version of the Q45MAF. Im after the Q45 MAF as im planning more power than a Z32MAF will allow for, and i have the chance to get one cheap
Are the connectors on both still 3 pin ?
Thanks
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
its actually 90-94 and 95-96 that are different. Theyre technically the same MAF just with different connectors...
Q45tech
Besides the restriction of the wire screen to keep large chunks from hitting the MAF element, the inside diameter creates the pressure drop vs flow thru the unit.
Measure the pressure drop at whatever maximum flow you expect to size the diameter......for example the Q45 MAF has a 7" water column pressure restriction at ~~ 300 HP and reads 4.4 volts...........most MAF top out at 255 grams per second ~~ [380 HP]. 8 bit signal [0-255=256 steps]
lb/min x 7.5 = gm/sec or gm/sec x .132 = lb/min
The calibration grams per second of air vs the MAF voltage output is set by a group of resistances in the bridge circuit.
Inside the ecu software is an exponential equation [creates the scaling map] that translates the MAF voltage to something useful LIKE a VE% of that size [displacement] engine.....................
http://www.gnttype.org/techare....htmlh ... re...s.xls
Some engine use a real [measuring half of the cylinders] and a dummy maf and multiply the air flowing thru the real unit by 2.
PoorManQ45
Way to scare the newbie off Dennis. LOL
hannibal
Car: Red Line to Glenmont
My head hurts...
B120, the Q45 MAF is 90mm and the Z32 MAF is 80mm. But the Z32 MAF can read more airflow (over 500whp from what Ive read). I'm not sure where the Q45 MAF maxes out, but I think its less than the Z32's.
FYI, the Z32 NA and TT use the same MAF (labeled N62)...
Q45tech
part # 22680-30P00 75mm
In stock form the 300zxtt was designed for a peak of 9.5 psi which on the surface looks like [14.7+ 9.5]/14.7= 164% of 3.0 liters or ~~ 4.93 liters however the pressurizing adds heat which brings the air flow density down to roughly equal to what the Q45 injests.
While a stock Q can only show a 4.4 volt MAF peak..............the MAF continues to function up to 5.0 volts............which might be close to 300gms or 450 HP at some higher restriction.
Think you are missing the point that a MAF can support any amount of HP just that when the 5.0 volts is exceeded that the ecu won't know what to do.
si
Car: Q45, R32 GTR
z32 can suport up to 350rwkw (near 500hp)Q45 maf/afm has been known to reach 450rwkw(600hp)
So if your little SR is going to max out a z32 afm then you must be running a rather large turbo!
PoorManQ45
Q45tech wrote:Think you are missing the point that a MAF can support any amount of HP just that when the 5.0 volts is exceeded that the ecu won't know what to do.
Is it possible to alter the sending unit in the MAF to allow an output greater then 5V?
Or will this decrease the sensitivity/accuracy?
Q45tech
You are missing that the A to D convertor in ecu only generates digital words to 5.00 volts and 8 bits is only 256 steps...............also 7" W.C. is 1/4 psi flow restriction.
5.000 volts can be any flow you want as long as you are willing to accept the pressure drop across the MAF at that flow
1.0 psi restriction drops the barometric pressure thus density by 6.8% so most limit to 1/4 psi ~~ 1.7%.
At some point the MAF gets maxed out [5.0 volts] and then you use a MAP sensor to measure the boost pressure and IAT [temperature] to calculate the EXTRA density from supercharging..........this drives the ecu forward.
You spec a MAF at max grams per second at 5.0 volts with X pressure drop.
