Ozzie »
https://forums.nicoclub.com/ozzie-u33476.html
Tue Sep 12, 2006 4:40 am
Here's the story........
My active suspension has been playing up for the last 8 months....
When I checked for a code, it threw out 41..... pump or pressure switch system is faulty....(The front of the car would rais up when I started the car... sit steady for about 10 seconds, then slowly sink back down, until it reached the point where the "ACTSUS" light would come on)
I was at work, topping up the coolant before i left work (was running a bit warm on the way to work the night before).....
So after I started the engine, to pump any air out of the system, the car raised up as normal, then sank down......Being annoyed at it (as I always am), I pushed the front of the car down, and surprisingly, it kept sinking!!!! (I got the spoiler to touch my foot, while I had my foot underneath it when pushing down)
After the air bubbles ceased coming out of the spout, I replaced the cap, then got in the car.....
I turned the engine off, so I could re-start it, to pump the front up again...
It turned over a few times, and i stopped cranking the engine over.... There was a chuffing/popping sound once i released the key.
I went to re-start it again, and it fired right up.....(I had the switch set to the "H" or "high" setting for the suspension, which has a green indicator light in the gauge cluster.)
The car raised up IMMEDIATELY (unusual), and I proceeded to drive off.By the exit of the carpark, the height light was still on (unusual).... Then i got to the nearest main road... light was still on!
I got all the way home (approx 20 miles..) with no "ACTSUS" fault!
The suspension has been working great since!!!!
After 8 months, the suspension begins to work again!?!?!?!?
I don't get it!
Any ideas as to why this happened?
