Q45 abs/tcs/slip
jweth
Car: 1997 Q45
How do you reset the abs/tcs/slip lights? I have a 1997 Q. I have replaced the abs sensor as that was the code i recieved.Thanks
Jamie
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Welcome to the club.
Have you tested your alternator? How old is the battery?
There was a recall that year. Does you Infiniti dealer performed service history show it was replaced?
jweth
Car: 1997 Q45
Thanks for the welcome. Looks like alot of info here. I had a friend who has the equipment to check the codes and the abs relay is the code i recieved. I have replaced that and was just looking for info on how to reset the lights in the dash or do i have to go hook it back up to the computer again to have it reset? Oh yeah! I just put a new battery in it and the alternator is charging properly.
Thanks
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
i don't believe any reset is required if the alternator is performing under load properly. Voltage output alone is not a sufficient test.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
The ABS/TCS/SLIP lights dont really apply to the Y33s like they do for G50s for alternator.. Usually when the "christmas tree" comes on, youll start noticing other things.....
Anyway, ive seen this before on Y33s.. And i think if you unplug the battery overnight, that should take care of it...
elwesso
2007 BMW M Coupe
Moved to online mechanic.
jweth
Car: 1997 Q45
Thanks! I'll try that.
