q45 A/C electric cooling fan under hood
pjq45
Car: 1993 Q45
my cooling was not working when I put the a/c on..... So when I ripped it apart the fan was frozen..... I replaced the fan with a good working one..... and it still don't come on..... "Which Sucks" I check all the fuses and they are good and replaced the relay and it still don't work.... now what do I do?
qsiguy
Car: 1994 Infiniti Q45 Turbo
I can pull up the diagrams and give you some idea where to look, unfortunately I have to head out right now. If someone else hasn't helped already I'll pull them up tonight and give you a direction to start.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
The fan doenst turn on as soon as the AC comes on, it will only come on when it needs to. Might very well work, mine hardly ever comes on unless its hot outside.
pat lindy
Car: 1994 q45
i think my fan needs a bearing. makes loud rattling noise when on. do i need to remove radiator to get at this fan?
