elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Wed Mar 04, 2015 6:53 am
Welcome to NICO!
The fuel pump is located on the fuel tank, between the back seat and the trunk. I've never done a fuel pump on a second gen Q but I can't imagine it's that hard, probably 2-3 hour job. You may be able to access it entirely from inside the trunk, not sure if there's access from above from inside the cabin.
The belts and pulleys are straight forward. If you want to save a little money you can replace just the bearings in the pulleys if you have access to a press. I've done it myself a few times and it's way easy. New pulleys are about $100 each, versus $15 for bearings. The pulleys are made from metal so they won't wear. Same thing with the fan clutch, really straight forward to replace that.
I wouldn't change the intake, you won't gain anything there, just keep a fresh filter in the airbox and call it a day. There's not really a lot of performance stuff out there for this car that really truly gains HP. There are some suspension things you can do to tighten things up.
