q45 98 alternator belt replacement
Black98q45
Replacing belts fairly straight forward until replacing the alternator belt. Does not seem to want to go over the fan blade. There are a series of smaller bolts holding the fan blade on. Is this the correct approach?
FarFetched
Car: Suzuki SV1000S.
If you take fan blade off, you will have easier approach to all belts!Cheers!
Black98q45
I have 2 of 3 completed and was wanting to avoid the fan removal for the 3rd.
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
01 B15 Sentra (Daughter's)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
Black98q45 wrote:I have 2 of 3 completed and was wanting to avoid the fan removal for the 3rd.
2 of 3? i thought there were 4. don't forget the belt that only drives the wp, so the wp can drive the alt.
Black98q45
Took fan loose out with old and in with new. Not too difficult. Autoparts guy gave me 4 belts, you mentioned 4 belts but I only see 3 belts and it is all buttoned up now. Well something to look at tommorrow.
FarFetched
when you get alt belt off, you will se 4th one behind it. kinda hidden!Cheers!Alt belt, a/c belt, w/p belt, p/s belt!
Black98q45
Yep 4. Thx for the advice. Goes much faster the second time!!!!
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
That's weird! Only 3 belts on VH45DE, right?
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
right. on the fy33, belts was the first job i did after oil change. that belt that just drives the wp throws me for a loop.
