Q45 '96 A/C condenser cooling fan won't run
colem
Car: Q45
The condenser cooling fan won't run. I can get the fan to run by grounding it. The relay seems to be OK. Any idea what the problem might be?
Thanks,
Mike
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
The condensor fan does not come on all the time, it only comes on when high side AC pressure gets above a certain pressure.
The fan is set to come on when high side pressure is 206-220psi+ and then will turn off at about 178-192...
So basically if your high side pressure is below 200 then thats why your fan isnt coming on.
qship96
Car: 1996 Infiniti Q45
Ditto what Wes said,also comes on if coolant temp rises above set point,either on low or high depending on position of a/c switch
colem
Car: Q45
Thanks for the info. I've checked and the high side is above 200 psi, but the fan doesn't kick in. Where do I go from here?
Thanks,
Mike
qship96
colem wrote:Thanks for the info. I've checked and the high side is above 200 psi, but the fan doesn't kick in. Where do I go from here?
Thanks,
Mike
check relay,jump pins in relay socket-if still no go,inspect high pressure switch on dryer,inspect all wiring,but first hotwire fan directly with 12 volts to be sure motor isnt toast
elwesso
2007 BMW M Coupe
I would suspect the switch too... Ive found that sometimes mine doesnt come on either all the time.... FWIW.
