Rex »
https://forums.nicoclub.com/rex-u6324.html
Thu Mar 20, 2008 3:08 am
Search for a few threads about swapping Nissan/Infiniti OEM Bose units. There's an adapter needed for some and there's a guy on NICO that created an AuxIn iPod adapter, but it used the external CD Changer connection on the rear of the HU. My guess is a 6 disc changer HU won't have the necessary plug for an Aux-In.
To date we haven't found any Nissan/Infiniti OEM Bose units that won't fit, as long as they're the standard Double DIN size.
Removal of yours should be pretty strait forward.
1) Remove shifter bezel by lifting from the rear, be careful not to break off the tabs that hook under the ash tray.2) Disconnect window switches, move shifter bezel off to the side. I lay it upside down in the passenger seat to not scratch the leather.3) Remove the 4 screws in the corners of the opening created by removing the shifter bezel.4) Remove the ashtray, should be 2 connections.5) Remove the 2 screws exposed by the removed ashtray. They're up at the top of the ashtray opening.6) You should know be able to remove the panel that runs from the rear edge of the shifter opening, to up over the HVAC controls and over to the steering column. It's held in by a series of tabs, be careful not to break any of them. Usually helps to get them all loose the angle the section out to "untuck" it from the steering column. You'll need to disconnect a couple wires (rear def button I think??)7) Remove screws (4, maybe 6) that hold the HU and HVAC controller in place. You'll need to reach into the dash and disconnect both (1 for HVAC, 3 for HU) before pulling it too par out. Have keys handy in case you need to shift the car out of Park to clear the dash.
I think that's pretty much all the steps. Reverse the order to put it all back.
If you find any inaccuracies, let me know and I'll update this as it was from memory.
