A safe and prudent decision.Showtimesky wrote:I'll have it flat bed.
^^ I will and thanks again.Q451990 wrote:With "smoke" coming from that area, I'm going to bet it's an under-plenum hose. You're in good hands with T3. They will take good care of you - and work on more 1st generation Q45s than probably any other repair facility in the US if not the world.
Please keep us posted on what happens - and welcome to NICO!
Heath
showtime, i agree with all said here and T3 is very well respected. since you have a '91, they will in due diligence STRONGLY recommend that you replace your timing chain guides. that is no sales job--assuming yours have not been done--then you DO need to de-fuse the time bomb inside your engine. documented time and time again.96Qowner wrote:You're in luck! One of the best Q45 shops in the country is in Smyrna. Give them a call. They won't take unfair advantage of you - it's a well respected shop.
T3 Automotive Limited5322 South Cobb Drive SoutheastSmyrna, GA 30080(404) 794-7700
It's a genuine problem and has caused many engines to spontaneously blow. When the guides fail, the chain slips and the valves begin to hit the pistons - at great force - the engine is usually irreparable.Showtimesky wrote: Huh? is the time bomb the timing chain guides?
Wow... that sounds ominous - especially for an engine with such low mileage.Q45tech wrote:Please pause until the offical diagnosis..............I'm praying. Guides appear to be the least of its problems.
Heath
Bingo!Q451990 wrote:With "smoke" coming from that area, I'm going to bet it's an under-plenum hose. You're in good hands with T3. They will take good care of you - and work on more 1st generation Q45s than probably any other repair facility in the US if not the world.
Heath
OK, if it didn't overheat, on to the timing chain guides.Showtimesky wrote:Bingo!
Thanks for letting us know! Please don't wait too long on those timing chain guidesShowtimesky wrote:Thanks guys and gals for all of your help. Yes T3 fixed my car and it was the plenum hoses and I'll take care of the other problems some other time. Thanks Q451990.
