Q45 2piston/ 300zx 4piston calipers in REAR of 240??
E7-S14
Car: ess 14 foo!
i recently saw a shot of an s14 running z32 4polt calipers in the rear.
now i've been thinking of this for some time now and have been wondering is it possible to do with the q45 fronts.
im sure there are mounting bracket floating around somewhere on the webs for it, but then how would the e brake assembly work..
jw if anyone's thought of this or knows anything about it.
GoTRicEo0
Car: Slowest crap the earth have ever seen.
You could do anything you want. Just going to require brackets and a larger brake master.
If I find anything useful. I'll post the link for you.
-Jeff
~Edit. The ebrake should still work. The brake calliper changes but the shoe in the ebrake doesn't. If worst comes to worst.............. Hydro conversion :]
Modified by GoTRicEo0 at 10:11 PM 2/2/2010
r3v_v3ng3
Car: 91 fastback ka-t
but it looks like its using the front rotors also not the rear ones that has a drum setup
