Q45 (1st Gen): Removing Dash
Articles, troubleshooting, DIY's and how-to's for all Infiniti vehicles.
Article Manager
1. Fully Extend Steering Wheel
2. Fully Lower Steering Wheel
3. Place Gear Shifter in "D"
4. Remove Shifter Cover Plate (gently pry up back of plate located closest to you, and disconnect wire harnesses for power windows from plate) and set aside
5. Remove two screws at rear of shifter cover plate area
6. Remove two screws securing metal bar and ashtray assembly
7. Remove metal bar
8.Remove ashtray assembly
9. Remove two screws behind ashtray assembly location
10. Remove Forward Steering Wheel Housing Cover (closest to you-4 screws), housing is in two pieces upper and lower
11. Remove Rear Steering Wheel Housing Cover (4 screws, 3 outside and 1 inside lower half)
12. Gently pull housing (section covering A/C Controller and Car Stereo) away from dashboard (pull in down and out motion)
13. Disconnect wiring harness connectors
14. Gently Remove Left lower Dash plate (section around cruise control switch, mirror control, etc)
15. Disconnect wiring harness connectors
16. Remove 7 exposed screws from dashboard cover (5 lower, 2 upper)
17. Pull Outer Dash Housing (pry gently, side to side) and disconnect wiring harness connectors
18. Remove Outer Dash Housing
19. Remove 4 screws from Dash Display
20. Pull Dash Display
21. Invert Dash Display and remove the two screw in socket and bulb assemblies
22. Reverse procedure to reassemble
Contributed by: Daniel
Return to “Infiniti Articles”
