lino »
https://forums.nicoclub.com/lino-u31679.html
Fri Sep 03, 2010 6:17 am
Try putting a WTB advertisement in the classifieds section of the forum. Drew or someone might have have one and see your ad there.
Some info in case you didn't already know:
The part number of the 1993 TCU is either 31036-64U20 or 61036-64U75.
The TCU you want comes from a car made from 07/92 to 02/93.
Copied from another post....
"The TCU you want is from a 1993 model year with part number 31036-64U20 or 64U75. Later 94-96 TCUs will work too, but the transmission in those cars are geared differently than the one in the 90-93. For best results having the matching ECU is a good plan... you tend to get better redline shifts..."
"The difference between the 64U20 and 64U75 is the U75 was a counter-measure TCU that was installed to reduce torque converter shock in vehicles built before 2/1993 (VINS ending in 250083 or before). The TSB is ITB94-023.
The countermeasure part numbers for 1991 and 1992 models (2nd gear start) ended in 64U70 replacing 64U11 and 64U12 factory TCUs. Apparently this wasn't an issue on the 1990 transmissions."
