Q45 (1996) Very abruptly refuses to shift into any gear, Pretty Much disturbed.
ekuretawo
Car: Q45 Infiniti
AT 5.45p.m. this evening my Q was functioning perfectly except for a slight brake problem. Soon after that was fixed and the car test driven the gears will not shift into any ohther position other than Park. I find this pretty much disturbing. Any one with an idea on this problem? Will really appreciate your help.Thanks everyone contributing in anticipation.
Q45tech
Your description is unclear!Are you saying the shifter will not come out of park when you depress the brake pedal............how about when you use a tool to disengage the safety shift lock mechanism======= proceedure found in owners manual.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Please start with a detailed description the "slight brake problem" and what was done to repair it.
Then tell us the exact behavior in concise declarative sentences of the transmission or selector that is malfunctioning.
goody90q45
Car: 1992 Infiniti Q45 (sold)
Ekure- I think Tech and Maxnix are hinting that your brake issue and repair may be related to your transmission shift problem. As you know, the brake pedal has to be depressed in order to shift out of park and a sensor, relay or switch (not sure which or what) communicates between the two components. The shift lock (underneath the plastic cap you sold me thank you), allows you to shift out of park (dead battery, tow, etc.) overriding the relay/sensor/switch mentioned above. If you can get it out of park using the shift lock mechanism then chances are your transmission's OK and the problem is related to your brake issue/repair. Let us know what your brake repair involved. Good Luck.
ekuretawo
Car: Q45 Infiniti
My brake light on the dash was showing red. I checked and discovered that the brake master cylinder was leaking because each time I topped the brake fluid the light went off. I then went on to replace the brake master cylinder, after which the mechanic bleeded the brakes. Took the car on a test drive and everything seemed fine, with all the gears shifting nicely. Not long after, while the gear was in park, it would not shift into any of the other gears.Following a response from Mike on this forum, I depressed the shift lock mechanism and the gear came out of the park into other gears. I have tried this a number of times and it worked, unfortunately, the shift lock spring is now stuck inside and does not work anymore, effectively bring me back to where I started if not worse. What could be going on?
ekuretawo
Car: Q45 Infiniti
ekuretawo
Car: Q45 Infiniti
Q45tech
There are 2 [two] switches on brake pedal arm [brake lights] and Shift lock release solenoid.............check operation of the switch.......or at worst the entire shift mechanism needs replacing........get it in gear and visit T3 on South [email protected] believe we have a few mechanism in our fleet of junker/parts cars [we have a 1995] out back.
ekuretawo
Car: Q45 Infiniti
I definitely need to get to T3 on South Cobb, but have no clue of their address or telephone numbers. Could you please assist?
Q45tech
404-794-7700 , South Cobb just 100 feet inside I285 [2nd driveway]
