Q45, 1994: NGK PFR6G-11 or PFR5G-11 Spark Plugs?
PachoC
Hello,Quick question: According to the owner's manual (Q45, 1994) the Standard spark plugs are the PFR5G; the PFR6G are supposedly "cold". Infinitipartsusa recommends the PFR6G. Are these ok? What is the main difference between the two? Which one will give the best performance? IS it better to stay with the PFR5G?Tks.
Q45tech
Depends on your location [Canada or Arizona] and your driving style.Long high speed drives daily vs crank and drive 5 miles, then constant repeats.
The worst for fouling is the 5 mile/10-15 minute operation needs hotter plug. Blended mix needs middle range.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
For the 94 Q the stock plugs were the 5g's
Unless you always get the car up to operating temp or regualrly redline the car, the 5g's are what you want.
There was a TSB about switching from the 5Gs to the 6Gs... they say theres no performance difference in the TSB... but the hotter plugs are obviously less likely to foul.
PachoC
This is defenitely my case: Short (15 to 20 minutes) daily runs with only a couple of relatively hard accelerations (4~5k RPM) going up a hill.Based on this I guess I should stick with the PFR5G's. Correct? I just don't want to do all the work and later find out that I didn't use the right plugs!Tks.
PachoC
Wess, Where could I find the TSB you refer to? I just want to learn a little bit about this stuff.Tks.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
PachoC wrote:Where could I find the TSB you refer to? I just want to learn a little bit about this stuff.
http://www.nissan-techinfo.com/infiniti/ has all the TSB and FSM from 1994 on.
One day subscription costs $20, the best investment you can make.
In WA state, you should use the 6. If it is Western Australia, the 5 might be good in the summer.
elwesso
2007 BMW M Coupe
acutally thats backwards. If you live in warmer climate youd want to use a colder plug, if you live in colder climate youd want to use the hotter plug (has to do with the amount of time at super rich warmup)
PachoC
I am going to stick with the 5's since these are the OEM.Tks a lot for your feedback!
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
elwesso wrote:acutally thats backwards. If you live in warmer climate youd want to use a colder plug, if you live in colder climate youd want to use the hotter plug (has to do with the amount of time at super rich warmup)
Wes is right. Drugs giving me brain freeze.
PachoC
Time for some BG44K with ice?
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
PachoC wrote:Time for some BG44K with ice?
More like BG44K with ISO-HEET!
elwesso
2007 BMW M Coupe
44k on the rocks... Should get you feelin good after one...
Jeff Williams
Car: 1994 Infiniti Q45t
2000 Infiniti I30t
2004 Infiniti M45
71, 72, 73, 82 & 2000 Corvettes
Wes, can you still get deals on these plugs?
I have about 40k on mine, and want to change them out.
I want to go to the colder plug, due to the NICO ECU and my warm climate and driver's style.
Thanks!
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Joe had a great deal on them a while ago. I think Wes' contact turned flakey.
elwesso
2007 BMW M Coupe
Jeff Williams wrote:Wes, can you still get deals on these plugs?
Thanks!
dude my hookup has been long gone, probably 2 years almost now... Joe sells the 6's im sure he'd still hook you up.
