Q45 1994 - KS Wiring Harness Part #?
Mint Q45A
Car: 1994 Q45A
Does anybody have the part # for the Wiring Harness for the knock sensors for the Q? I ordered it and what I got doesn't look right... but I may be wrongI have not removed the plenum yet, therefore I don't know how it looks like. I assume it is some sort of "Y" arrangement that connects to both KS (and maybe, to the Temp sensor). Am I right? Tks!!
qship96
Car: 1996 Infiniti Q45
The harness should have one plug on one end and 3 on the other...1 for each knock sensor,1 for temp sensor.
I remember hearing the 94 q model having 2 different harness part numbers,based on production date...sometime during the 94 model year,harness was changed and used thru 96.
Mint Q45A
Car: 1994 Q45A
That's what I thought....I guess I got the wrong part.Approximately how much ($) should it cost?Tks!!
qship96
Later model harness retails for about $60,joe sells it for around 40 if I recall correctly-I think the earlier version was about 2x the price
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Mint Q45A wrote:Approximately how much ($) should it cost?
Check with Joe, but I think $60 or less.
Mint Q45A
Car: 1994 Q45A
So $15.00 was probably not right... My dilema now: Install the KS with the old harness or spend more $ and replace the harness too...I understand that it is very rare for the harness to fail...
qship96
just make sure plastic connectors are not cracked/broken,and use some electrical parts cleaner to clean any oxidation from terminals in each connector-spray and scrub with a small pipe cleaner
I have had great luck using Caig de-ox-it cleaner and protectant on all electrical connectors of my home stereo....order on line,or most radio-shack stores sell Caig products.
Mint Q45A
Car: 1994 Q45A
Cool...Tks for the advise!
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
01 B15 Sentra (Daughter's)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
silver is 07/93 production and used the 2407960u00 (early) harness.
Q451990
Mint Q45A wrote:I understand that it is very rare for the harness to fail...
Actually harness failure is pretty common. I would absolutely wait to buy that harness before you button everything up.
Heath
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Heath
Do you really want to go in there again? T-3 always replaces them all together.
$37.37 from Joe, unless you have the early VH45DE then $116+
