Q451990owner wrote:The car was sitting for 8 years, fuel pump corroded, was replaced. The car was driven 8 mikes, parked again for 2 years. Pump corroded again and replaced.
This time the engine would not turn on. I was sure the injectors were clogged.i called AAA and had it towed to shop, when the car was lowered from the flat bed, it started right away....
But it was vibrating, they hooked it up to a computer and it said injector 1 and 8 not working at 0 RPM. And the rest were about 75-80 RPM
The mechanic says he needed to take off the plamium and wanted $400 for that then replace the 2 injectors.
I don't trust this guy , I bought injector cleaner fluid, and drove the car for 40 miles, but still 2 injectors are not working.
Could it be the spark plugs and not the injectors? Could it be that a rat chewed a cable? I had rat droppings in the engine.
Can I clean the injectors? Can the injectors 1 and 8 be pulled out without removing the plamium?
A mechanic , different one, who deals with infinities all the time, says that the injector will most likely work all of a sudden if I drive the car for a couple of days.
Any suggestions? Opinions?
Thanks
Varmint's usually like to chew up the knock sensor wiring harness. At 115,000 miles mine had been chewed down to one small strand of wire. I replaced the knock sensor harness when I pulled to plenum to replace fuel injectors.
Soon after I purchased my Q, I installed spark plugs and found the valve cover RTV (liquid gasket sealer) was leaking around spark plugs 1 and 2. The uncorrected oil leak would eventually cause firing to fail on cylinders 1 and 2. About a week later the car developed a miss that turned out to be two bad injectors (IIRC) on cylinders 2 and 7. So my V8 had become a V6.
The Phase I Q45 (1990 - 1993) model used plastic timing chain guides. If the plastic guides have not been replaced, you should start making plans for replacement. If the timing chain guides break, the engine will most likely be destroyed. Also, Phase I Q45 used a pintile style injector. The Phase II Q45 used a rotary injector that seems to be more reliable. I would consider replacing all injectors with new rotary style injectors and the Phase II injector rail and wiring harness.
The Crossroads
In July of 2010 I had just acquired a mint condition Q45 with 115,000 miles. I knew the car had been in a climate controlled garage since it was new. Also, the car had no door dings or visible signs of upholstery wear. I knew from the start the car would need timing chain guides and all new hoses since it was approaching 20 years old. The injector failure was a complete surprise.
The good news is I had budgeted $3,000 for first year parts and repairs and another $1,500 for second year parts and repairs knowing I would refresh critical technical components during that process. After learning about the Q45 on this forum I decided to do my own labor as the money saved could be used to do a first class tech refresh and replace all under plenum hoses, varmint chewed wiring, injectors, timing chain guides, alternator, radiator, struts, and other wear items. Trust me, I spent at least $4,500 on parts for the first year with me supplying the labor. Also, I wanted to make the Q's restoration a family project for my two teenage sons so they could learn about fixing up a car with fuel injection and computerized ignition like we have with the Q. Unfortunately, the transmission failed during the second year of service, so I was committed to keeping the car rolling as I had spent a lot of time and money during the tech refresh.
Remember we have cars that will be officially classified (at least in my state) for licensing purposes as an "
antique automobile" within the next couple of years. Antique car license plates (a one time license fee) and special tax discounts are available for automobiles over 25 years old. So if you are willing to spend the money to give the Q an under plenum technology refresh, then drive it to get your money's worth out of the repair investment as automobile expense like depreciation, it may be worth it to you to keep and drive it as an antique automobile. Otherwise, I would consider selling it to someone who will make the technology refresh investment and keep the car for several years while registering it as an antique automobile.
