rabsusa wrote:1.) tires are no name 340 AA, good enough?
2.) OAT?? idk what that is; i used fresh green stuff - prestone - not opened thermostat, as no heating issues. New caps fitted.
3.) K&N has replacement filter, was thinking of using that.....fuel filter, not replaced yet - will be oem.
4.) indeed, but i dont want to spend excessive monies running her if its going to break
1.) Only thing in contact with the road and thus are the final arbiter of performance is everything else is up to OEM new snuff, so your choice. Compound is too hard, but if you are not running TCS, you should be OK. Look out for rian, corners, emergency stops, and high speed.
2.) Organic Acid Technology - longer life, less corrosion. Distilled water as a dilutant? OEM caps?
3.) K&N is the worst thing you can do, besides use sub 91 octane. Oiled filter elements in front of a hot wire sensor is not a good thing for the snesor.
4.) Unless previouisly abused or not maintained, G50 don't break.
Don't think any Volvo is on the same plane as a G50, not for a second.
Your are doing well, just keep going and realize the penalty any shortcuts entail. Your car will be as good as you make it.
