Q won't start. 60hz hum (fuel pump like) sound.
ddrumman
Car: 08 FX35 39,000 mi, 07 G35 55,500 mi, 72 MGB
My wife and two of her colleagues (ladies) came home early yesterday to go to a Dodger game against the Braves.So we were gonna take the Q since it’s the 4 seater. I get in it; turn the key and all I get is that fuel pump LIKE sound. It will not even turn over. If the battery is weak or bad it should at least turn over or do that crrr crrr sound. The lights were fine, the horn was a little weak though. My fuel pump is brand new, as I changed it last summer. I wanted to know, before I take it in if this has ever happened to any of you guys.
goody90q45
Car: 1992 Infiniti Q45 (sold)
How old is your battery?
ddrumman
goody94q45 wrote:How old is your battery?
It's about three to four months old. Red Top Optima.
D.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
so you turned the key and it didnt do anything..... I dont think its the battery... esp since it sa redtop optima
Id try wiggling the key while its in the ignition, maybe wasnt getting a good connection?
squeefoo
Car: 1990 Infiniti Q45
1994 Nissan Maxima SE
1999 Infiniti I30
2003 Nissan Maxima Titanium
2006 Nissan Xterra Off Road
2012 Infiniti G37x S
Check the Starter relay?
Right behind the battery.
Jeff Williams
Car: 1994 Infiniti Q45t
2000 Infiniti I30t
2004 Infiniti M45
71, 72, 73, 82 & 2000 Corvettes
Try the shift lockout. Put the car in "N" to see if it will start then.
Red Tops do go bad, but the car should turn over.
Check the fuses, too.
The hum sounds like a short somewhere.
elwesso
2007 BMW M Coupe
Jeff Williams wrote:Try the shift lockout. Put the car in "N" to see if it will start then.
naw because the pump also runs while your turning the key, on high speed. the pump does make noise at hight speed.
I agree with your first idea too, i was going to suggest that as well..
ddrumman
squeefoo wrote:Check the Starter relay?
Is where my finger pointing the starter relay?
This is why I LOVE Nico.
Jeff you nailed it. I just put it in neutral and after turning over s l o w l y it started. WOW.So.... what could it be?
ddrumman
ddrumman wrote:So.... what could it be?
A couple of weeks ago I was doing 75 on the fwy when I heard a sound like a flat tire but the car felt fine. It ended up being the black cover that you unscrew to do the oil changes. It just snapped off and by being dragged around really scratched up the underneath of bumper. Anyway, it's been raining like crazy in SoCal the last month. Could the fact that the cover is not there any more, be the cause of a short in the electrical somewhere?
squeefoo
1999 Infiniti I30
You put your finger right on it!
The belly pan helps draw air through the radiator. Recommended to keep it on since the cooling system is not oversized.
ddrumman
squeefoo wrote:You put your finger right on it!
Got it!
As far as the car not starting though, do you think that the "pan belly" not being there has anything to do with it, letting water through and what not?
squeefoo
1999 Infiniti I30
At the risk of oversimplification, it does sound like the neutral safety switch if the above worked...
