Thanks to EBay I am now the proud possesor of an accurate 0.01-50G.[in/sec & mils displacement]......0.1Hz-1000Hz Vibration analyser/meter. Once modified and frequency shaped and fed into a precision external DSP sound card [$150] and spectrum analyser FFT software [free I hope] in a lap top. I should have a portable system close [in accuracy] to the $100,000 units used by vehicle engineers.If anyone knows where a flat SAE seat bottom/back sensor [accelerometer] could be acquired on the cheap.
Most of the annoying vibrations occur from 5-20 Hz [tires wheels] and are less than 0.3 G even on severe roads.
http://www.teamcorporation.com...s.pdfhttp://www-staff.lboro.ac.uk/~...1.pdfhttp://www.atsb.gov.au/road/rp...#comp"Steering wheel accelerations were found to be higher than the seat vibrations in some cases (Sweatman & McFarlane, 2000). Most vibration was in the range 8 - 15 Hz at levels in the range 0.4 - 1.0 m/s2. Given the long exposure durations there may be a small risk of adverse effects on the hand/arm at the higher exposure levels. "
http://gsaek.kookmin.ac.kr/pro...t.pdf
